• You're one step from joining Suzuki GSX-R – Sportbike Performance, Mods & Racing Upgrades.
    Create a free account to post, follow threads, and never miss an update.  Sign up free →
For Sale NAKED 88 Suzuki GSX 600 F AirHead/OilHead – restoration, or parts bike. Bill Of Sale only $ 400.00
Status
Not open for further replies.
blutoe
New member
Joined
Oct 7, 2025
Messages
0
NAKED 88 Suzuki GSX 600 F Air Head / Oil Head –For restoration, Track bike or parts bike. Bill Of Sale only. No title, true mileage unknown because P.O. turned this GSXF into a parts bike.I always wanted to own an air / oil head bike. Since I couldn’t afford a BMW I picked up this GSXF mechanics special instead. I took advantage of the Kat Riders blog and conducted my research to learn and gain a deep familiarity with the platform, and procured the materials and parts needed to rebuild the mini Gixer.Unfortunately, I do not like the design of the 88-89 600 or 88-93 1100 CV carbs (BST31SS and BST34SS). These carbs had vacuum diaphragms that were a complex rubber molded unitized diaphragm assembly that were exorbitantly expensive. By using later model interchangeable parts (1990, BST33SS carb rack) the desired conversion can be accomplished by using the OEM modified Suzuki’s separate diagrams and separate carb slides designed into the BST33SS carb rack.Therefore I collected all of the parts needed to convert THIS 88 GSX 600 F and I learned how to convert the 88's fuel induction to 1990 BST33SS carbs with Suzuki’s redesigned and order of magnitude less money vacuum diaphragms. Good thing for you is it's fairly easy to modify the bike to use the (supplied) 1990 BST33SS carbs.The bike parts that I have collected to use in order to put this back on the road as a road bike are as follows:1. Headers with mufflers2. 1990 BST33SS carb bank3. 1990 carb air box As far as the air box, the air box is the same, but the air box boots are not.4. Dash gauge pod5. Factory Workshop Manual6. 89-97 left handle bar switch with a choke lever and a choke cable.7. Air box filter8. old original parts. The bike parts that I have NOT collected to use in order to put this bike back on the road are as follows:1. 1990 thru 1997 GSXF tank (dual petcock for carbs dual fuel stubs)2. Front Radiator3. Front rotors4. Front calipers5. front brake pads6. Seat7. Fairing if desirered8. Turn signal stubs. Bike is located in LAS CRUCES, NEW MEXICO 88011
    57.8 KB
    59.3 KB
    59.3 KB
    64.5 KB
    108.1 KB
    121.4 KB
Status
Back
Top
