• You're one step from joining Suzuki GSX-R – Sportbike Performance, Mods & Racing Upgrades.
    Create a free account to post, follow threads, and never miss an update.  Sign up free →
Wiring adventures
dtitan25
Member
Joined
Aug 3, 2025
Messages
6
I'm trying to sort out the wiring on my barely-used GSXR 1000 k5 and cant find where the two wires for the left front indicator connect in the loom . I've found the ones for the right indicator and the position light, but the black and black/white wires for the left are missing. Its driving me crazy... any help or a pic would be a lifesaver.
My wife ran into the same issue on her K5, we tried gently pulling back the inner fairing panel around the front left, you should find them bundled close to the main loom, something led to the other and we ended making some things so we had to give a mechanic but I think that was error on our path and you can try this, hope that helps
Got it, thanks for sharing your experience, that actually helps narrow down where i should be looking. When you pulled back the inner fairing, were the wires fairly easy to separate from the loom or were they taped up pretty tight? Id rather not end up in the same situation where it turns into a bigger job than expected
Back
Top
